15 years agofsm debuging
fsm debugging Hi I started to check the fsm on real time and got some strange behaviors. I tried working with SignalTap but I didn't like the way he display the waves and we didn't really get ho...
15 years agoI didn't compile the test bench in quartus only the main entity and its components.
the flag is a port I wanted to add in order to sign the main entity that the process is over but I can also take the pwm port from the component and assign it directly to a pin but then it want be visual in the main entity
