13 years agoFrom one Ethernet to the other
First of all, I don't want to use TSE, I know that is easier but the thing is that I don't want to use the mac address, only take the data without changes and resend. The only thing that I wan...
13 years agoI understood the problem is pinging from pc B to pc A. Not from eth0 to eth1 or from eth1 to eth0 on your board. Is this right?
I believe you have already checked TCP/IP configuration for the two NICs, in particular the subnet mask. Did you try pinging between the two PCs without the boards? Does this work?
