13 years agoFrom one Ethernet to the other
First of all, I don't want to use TSE, I know that is easier but the thing is that I don't want to use the mac address, only take the data without changes and resend. The only thing that I wan...
13 years agoI know that the mode should be the same, with a ping should it work?
About the clocks, if I'm only wiring from one connector to the other, should I take care about the synchronization if I'm only connecting one input with one output?? I thought that the mdio is preconfigured in this kit and is not needed to be configured for this purpose, am I wrong?? if yes, I thought that there was an ipcore from altera for this configuration but I do't find it, do I need nios? because I'd to avoid its use Thank you very very much for your reply =)
