15 years agoFrom Custom Instruction to Custom Peripheral
I'm trying to simulate how a camera works by generating lines of data and then apply some kind of spatial 3x3 convolution filter to the data. I have done one method by using Custom Instruction where ...
15 years agoHi,
Here is my situation, I have an electronic board with an EP2C20F484I8N and EPCS4N. The programmation occurs properly and when i test the output pins, all of them are tristated. When i put to usb blaster on his connector, it works correctly and i received some good signals. The problem occurs when the Usb Blaster is not connected to the board. Could you help me? Thanks for advance
