13 years agoFrequency of operation of M9K bram
Hi, Does anybody know where/how to find the operating frequency of a block ram? I particularly need M9K and M10K. I was not able to find them in the altera documentation. Kindly let me know if ...
13 years ago --- Quote Start --- ... is uninferred due to inappropriate RAM size Please suggest how I can overcome the issue. --- Quote End --- Infer an appropriate RAM size :) M9K = 9kBits, 256 x 32-bits is ok in terms of the number of bits, but you also need to check that the device you are targeting supports that particular data width. Your design files do not include a project, so I can't tell which device you are targeting. Assuming you are targeting a Cyclone IV: http://www.altera.com/literature/hb/cyclone-iv/cyclone4-handbook.pdf p22 tells you that true dual-port mode only supports 16/18-bit data, so you need two blocks of M9K to create a 256 x 32-bit block, but you would use 512 x 36-bits of M9K, so you may as well increase the address width. I guess the Quartus inferrence engine is not too smart ... another reason to just instantiate an altsyncram (or two) directly :) Cheers, Dave
