14 years agoFrequency Divider Timing Req. Never Met
I am trying to make a freq. divider and tried many VHDL solutions on the web. Most of them worked but TimeQuest always tells timing requirements did not met. Here is one code that worked with a worst...
14 years ago --- Quote Start --- Oops? IMHO if not explicitly told by using
set_clock_groups -asynchronous -group { clk1 clk2_derived_from_clk1 } -group {clk3_unrelated} ... TQ treats all clocks as being related and may thus flag timing errors between certain clocks, even if you have added anti-metastabiity provisions. --- Quote End --- Those kind of clocks should be considered as asynchronous group like this then. Thank you very much.
