10 years agoFrequency counter with Altera
Hello, I have a draft measure with a frequency up to 1 ghz with Max II , I do not know which component to choose, I want to use a measure of reciprocal method . is that someone has a code...
10 years ago --- Quote Start --- You won't get anywhere near to 1GHz with a MAX II device. I think you need to reconsider or explain your requirements with a little more detail. Cheers, Alex --- Quote End --- Hello, I want to achieve a frequency 2 entries with a fpga , the range of each entry is 0 Hz to 1 GHz , the measurement method is reciprocal , the Communicatin between the FPGA and the CPU is with spi bus, the display is on an LCD touch screen . I do not know how to choose the fpga and I want a sample code to perform frequency measurements. the clock on the fpga is a 10 MHz OCXO oscillator. Thanks for your help. sebastien
