16 years agoFrame buffer IP
We use 2 frame buffer IPs in our design. 1- The first frame buffer: takes its data (din) from DVI Input IP (VGA_IN_INST) and writes this data into an SDRAM through the SDRAM controller. We d...
15 years agoI think that most SOPC components automatically fix the width of the empty signal depending on the number of symbols per bit that you set up.
Check that the two blocks you connect are set up with the same symbol width and the same number of symbols per beat.
