16 years agoFrame buffer IP
We use 2 frame buffer IPs in our design. 1- The first frame buffer: takes its data (din) from DVI Input IP (VGA_IN_INST) and writes this data into an SDRAM through the SDRAM controller. We d...
16 years agoIn our design using SOPC Builder we want to connect the output port (Avalon stream source) of an IP (clocked video output) to 2 other IPs. But it is not accepted. The clocked video output accepts to be connected to one IP only.
Kindly advise if there is any block or component or certain IP can be used to solve this problem.
