10 years agoFPGA to Optical NoC
Hi guys. I am having a research on optical NoCs and one of its requirements is the scheduling of the packets and I was able to implement a scheduling algorithm in an FPGA. This time, I wanted to inte...
10 years agoDepending on the requirements of your device, you might also use the FPGA to generate a pulse width modulation (PWM) signal and then filter that to get your analog voltage. A DAC would be more accurate PWM is easier to implement.
