Ben_Kim
6 years ago[FPGA ot PC] How to transfer data from fpga to PC?
Hello. I have a question about data transfer.
In my case, n-bit (x-y) array data is stored in MAX 10(144pin qfp - 10M50SAE144I7G) per camera period, then I want to transfer the data to PC through U...
IDeyn
Contributor
6 years agoHi Ben_Kim!
Well, there are a multiple ways for transferring data from FPGA to the PC.
Probably the easiest is through the JTAG, specifically USB UART https://www.youtube.com/watch?v=7xJ9dhVDCwU
Also you can use Signal Tap and acquire data using MATLAB - https://www.youtube.com/watch?v=fUQUV2x-GVc // https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii53009.pdf - page 13–61
But in case you need to transfer data with higher speeds, it will be more difficult task.
Hope it helps.
Ivan
