18 years agoFPGA n00b PCB design
Hi everyone, I'm working on a PCB design for my first FPGA project. I've done a lot of microcontroller projects before, but with the new tech combined with a hard and fast-approaching deadline...
18 years ago --- Quote Start --- Regarding AS programming: Figure 10-7 is O.K. so far, however I have switched to SFL AS programming through JTAG. This is cause I always have JTAG interface in my designs and can avoid an additional connector and protection circuit. But as you have only one AS device, the additional part count and space requirement can be probably neglected, if JTAG is used at all. --- Quote End --- Great, I think I'll just stick with 10-7 since I don't need JTAG for this app. --- Quote Start --- Also with small load capacitance (and minimum drive strength) SSO may be an issue, I think. The effect can be seen even with a large number of unloaded pins switching simultaneously, only due to internal pin capacitance. It will cause VCCIO voltage drops and (more problematic) ground bounce, that is coupled e. g. to clock inputs, resulting possibly in PLL loss of lock. PQFP240 package has as a disadvantage long connection lengths with higher inductance, compared e. g. to FBGA. With 2-layer PCB, some additional inductance in ground and supply connections could be expected. I have experienced SSO issues only with Cyclone II PQFP package devices up to now, the few Cyclone III designs probably have been less critical due to other design parameters, I yet can't say for sure, that the situation has improved with Cyclone III. However, this could be expected regarding PLL problems, cause an internal PLL analog supply regulator has been introduced with Cyclone III. --- Quote End --- This is somewhat encouraging, as at least on the dev board my HDL design worked fine driving 128 unconnected pins. Of course there are a number of things working against me in the case of my hardware, like the package, 2 layer PCB, etc. Still good to know. --- Quote Start --- If you have an option to achieve time-displaced switching with your outputs, I would try to utilize it as a precaution. --- Quote End --- By this do you just mean staggering the switching in my design, or some other chip-specific feature? In your mind, am I correct to say that it seems that it's worth trying this on a 2 layer board, keeping these issues in mind? Also, do you have any pointers on where I might find resources on implementing a differential clock as you suggested in the earlier post? Any thoughts on the power layout as seen here: http://jamesnsears.com/temp/sears_altera_001.png Thanks again, -JNS.
