9 years agoFPGA Master Driven Coherent Memory Transactions Using Write/Read Masters on Linux
Hi, I'm trying to compare 3 fpga master driven memory transaction scenarios on altera cyclone v soc: - Connecting to SDRAM controller directly, - Connecting to SDRAM controller using F2H br...
8 years agoHey!
Some directions I would follow: - Is FPGA-HPS bridge enabled? (under "/sys/class/fpga_bridge") - Then I would check whether the data is actually written to the memory (while using non cached memory, at first). - If data is not there => How do You pass physical address to Your DMA IP core? I would be glad to look into it myself, of course if Your core is not under NDA or something...
