13 years agoFPGA instability after reset
Hi all, I am working with a custom Cyclone IV E based HW that is suffering from strange startup instability. The HW runs fine under various stress tests and temperature ranges when programmed...
13 years agoThe bootloader which runs from internal ram copies the actual firmware from EPCS flash to external SDRAM and jumps to its start address.
The problem is not in the bootloader or firmware code, they run just fine when downloaded through JTAG and most of the time after power on or reset. Just sometimes it happens that shortly after reset (toggling nCONFIG with a switch in my case) the system freezes. This happens on the cusom HW I work on, I didn't observe such behaviour on my developement kit.
