15 years agoFmax is small, please, help me to improve it!
Hi, in my small systemverilog project (about 1000 lines) I have one module that is critical to the performance (I attached it below). This module takes 4x16 bit words (In) per clock (Clk),...
15 years agoDear Josyb,
thank you for your kind answer. Would you, or somebody else, explain me, please, why unregistered memory provides such a delay, how to solve it, and why I get unregistered memory here? My questions occur due to the following: when you told about multipliers, I decide to put additional intermediate pipeline registers (in my attached code they are D1 and Data1) and I got some improvement for FMax:
N SHR FMAX 0C/85C Logic DSP Total Synt. Time
N=24, SHR=14, 363/336MHz, Logic 33%, DSP 100%, Time=56minutes
N=12, SHR=14, 376/346MHz, Logic 16%, DSP 50%, Time=19minutes
N= 6, SHR=14, 405/383MHz, Logic 8%, DSP 25%, Time= 9minutes
N=24, SHR= 2, 383/357MHz, Logic 29%, DSP 100%, Time=43minutes
N=12, SHR= 2, 407/380MHz, Logic 15%, DSP 50%, Time=23minutes
N= 6, SHR= 2, 443/413MHz, Logic 7%, DSP 25%, Time=12minutes
however, I cannot figure out myself when I should do these tricks, and what kind of other tricks are available for FMax improvement! PS: in my design I am free to append more pipeline stages, but where, please, help me with procedure to find it. I can see something in "Property Editor" however I cannot interpret it to make correct decision, please, help me!!! Thank you in advance! Sincerely, Ilghiz
module test(Clk, In, ClkSW, SW, Scal);
parameter N=6; // can be 2, 4, 6, ..., but I need 18 and dreaming about 24
parameter SHR=14; // can be 2, 3, 4, 5, ..., but I need 12-20
input Clk, ClkSW;
input signed In;
input SW;
reg signed Scal;
output Scal;
// Memory ////////////////////////////
reg signed D, Data;
reg signed D1, Data1; // new pipeline registers
reg signed Mul;
reg signed Sum, Sum2;
reg signed ScalX;
reg signed ScalY;
reg InDataCounter;
reg signed ScalY1, ScalY2; // new intermediate
reg signed ScalY3, ScalY4; // registers for simple output
// Reading Data from Channels - the key place where I cannot achieve to clock it with 400MHz for N=16 or 24
always @(posedge Clk)
begin
for(int i=0; i<2; i++)
for(int j=0; j<4; j++)
D<=Data;
Data<=In;
for(int i=0; i<N-1; i++)
Data<=Data;
InDataCounter<=~InDataCounter;
for(int i=0; i<N; i++)
Data1<=Data; // new pipeline registers that helps for small N
D1<=D; // new pipeline registers that helps for small N
for(int i=0; i<N; i+=2)
for(int k=0; k<4; k++)
begin
Mul <=D1*Data1;
Mul<=D1*Data1;
end
for(int j=0; j<16; j++)
begin
Sum<=Mul+Mul;
Sum2<=Sum;
ScalX<=ScalX-(ScalX>>>SHR);
ScalX<=Sum2+ScalX;
ScalY<=ScalX>>>(16+SHR);
end
end
// Output - different from previous one, just to save space...
always @(posedge ClkSW)
begin
for(int j=0; j<16; j+=2)
ScalY1<=ScalY+j];
for(int j=0; j<8; j+=2)
ScalY2<=ScalY1+j];
for(int j=0; j<4; j+=2)
ScalY3<=ScalY2+j];
ScalY4<=ScalY3];
Scal<=ScalY4];
end
endmodule
