15 years agoFlash programmer select file FAILs
From NIOS II IDE I select NIOS II Flash Programmer. Then select File, new and with the BSP Settings file radio button selected try to browse for my settings.bsp file ...... BUT ...... When pushing th...
15 years agoHi
I run Windows 7 on a HP 8600 Workstation (no terminal). The problem always happens. Also if I start Nios II IDE with "run as administrator". However a colleague of mine run the same tools with the same version, also on Win7, but he can browse !? Maybe I need to reinstall the tool - but otherwise the tools works nicely when e.g. debugging or running through the JTAG connection - so I don´t really think a reinstall will help. So far we can´t see any difference in tool setting either. Very strange ... But maybe you have a point about the right to browse ... --- Quote Start --- Maybe Altera tools don't have the rights to browse. --- Quote End ---
