15 years agoFlash problem and "No CFI table found"
Hello, running the nios2-flash-programmer.exe from the nios2 command console with the --debug option (nios2-flash-programmer -b 0x00 --debug ) the output is: Using cable "USB-Blaster [USB...
15 years agoI don't remember which timings I found. It depends obviously of the CFI component AND the routing.
http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf http://www.altera.com/literature/ug/ug_embedded_ip.pdf See "Offship Interface Peripherals" > Common Flash Interface > Configuration > "Timing Page" (p. 47) It is not so obvious. It demands a little work of searching in datasheet.
