15 years agoFlash problem and "No CFI table found"
Hello, running the nios2-flash-programmer.exe from the nios2 command console with the --debug option (nios2-flash-programmer -b 0x00 --debug ) the output is: Using cable "USB-Blaster [USB...
15 years agoI've solved the problem!
Cheking the flash configuration in SOPC Builder I've found a mistake in flash "access time": it didn't match with the value in datasheet so the flash couldn't work.
