15 years agoFlash problem and "No CFI table found"
Hello, running the nios2-flash-programmer.exe from the nios2 command console with the --debug option (nios2-flash-programmer -b 0x00 --debug ) the output is: Using cable "USB-Blaster [USB...
15 years agoThanks for your answers.
# RST signal is ok and the address is right (0x00000000). Also setup, wait, hold times are right. I'll try to check again everything but if anybody have another idea please help me. @metalous About override file: it doesn't exist but you can create it looking "Nios II Flash Programmer User Guide" (Appendix A, Non-Standard Flash memories) and your flash datasheet.
