15 years agoFlash problem and "No CFI table found"
Hello, running the nios2-flash-programmer.exe from the nios2 command console with the --debug option (nios2-flash-programmer -b 0x00 --debug ) the output is: Using cable "USB-Blaster [USB...
15 years agoHello,
Did you check the flash# RST signal ? Are you sure your flash is at address 0x00000000 ? Regards, Franck.
