15 years agoFlash memory share for POF and NIOS HEX
Hi i have a question related to a NIOS application on S3 devkit. As you probably know this kit has a flash memory which can be used to set up the S3 with an on board Max device which does a para...
15 years agoIf the lanes are placed correctly ad use some kind of handshake between the Parallel Flash Loader in Max II, it will work as worked for me.
