15 years agoFlash memory share for POF and NIOS HEX
Hi i have a question related to a NIOS application on S3 devkit. As you probably know this kit has a flash memory which can be used to set up the S3 with an on board Max device which does a para...
15 years agoThanks again.
If I understood well, I can play with the possible pages while doing the Convert Programming File. In fact I simply need a Copy loader, to be more precise: -- The NIOS boots on on chip memory throughout what comes inside the reguler configuration POF -- the first think NIOS does is fetching the HEX or EXE and copy it from the flash to a DDR (or elsewhere) and jump to it. That's exactly what you've stated in your reply. I just wonder if this would interfere with the MAX II which is reading pages of the flash to get the POF to set up the S3 in PP scheme. I'll give a try and let you know. Regards
