15 years agoFlash memory share for POF and NIOS HEX
Hi i have a question related to a NIOS application on S3 devkit. As you probably know this kit has a flash memory which can be used to set up the S3 with an on board Max device which does a para...
15 years agoHi
Thank you for your reply. I already used that feature in a previous design where the software actually fitted in the on chip memory. No I've another design which weights 600K and my intention is to store that in the on board flash. But as I said, it is also used by the device's initialization POF. I have added the "External Flash Interface" in the design, that works but I have no idea how to put both POF and the 600K EXE of the NIOS in that memory and recover it after the device is set. K.r. Thouthi38
