15 years agoFlash memory share for POF and NIOS HEX
Hi i have a question related to a NIOS application on S3 devkit. As you probably know this kit has a flash memory which can be used to set up the S3 with an on board Max device which does a para...
15 years agoRegarding your first question, the concatenation is between the SOF and the HEX. You can concatenate both in one single POF with the convert programming file tool in Quartus II.
