15 years agoFlash memory problem
Hello, is it true that I cannot write 1MB of data into flash memory (4M)? I am using Altera DE2 Board. My code is as follow: --- Quote Start --- # include <stdio.h># include <stdlib.h...
15 years agoFirst of all get information about your flash device.
After alt_flash_open_dev call, define alt_flash_cfi_dev* flash = (alt_flash_cfi_dev*)fd; Then you can read: flash->dev.number_of_regions For every flash region: flash->dev.region_info.offsetflash->dev.region_info.region_size flash->dev.region_info.number_of_blocks
flash->dev.region_info.block_size Probably you have a single flash region, so you need read these only for i=0 If block_size is indeed 64kB then my supposition is probably correct and you must limit write size to 64kB (and align writes to block boundaries) You can simply do something like this: int addr = 0; while (addr < size) { //Write data into flash ret_code = alt_write_flash(fd, addr, src_ptr+addr, 0x10000); if(ret_code != 0) { printf("Error writing into flash: %d\n", ret_code); exit(1); } addr += 0x10000; // next 64kb block }
