14 years agoFixed Point VHDL Support in Quartus
I am asking how people have found the synthesis results with the new VHDL2008 package for fixed point. I have created a design that is a cascaded filter simulating a three phase RL load for a motor c...
13 years agoHi,
I am doing my Final year project including the floating point calculation. Anyone here know how to convert floating point number into integer with using the floating point package float_pkg_c.vhdl ? I already tried with the code below (a simply floating point addition and convert the summation into integer) but it show me this error --> "Error (10454): VHDL syntax error at float_pkg_c.vhdl(4314): right bound of range must be a constant" .Anyone here can help me to solve it? thanks. Code: library ieee; use ieee.std_logic_1164.all; library ieee_proposed; use ieee_proposed.fixed_float_types.all; -- ieee in the release use ieee_proposed.float_pkg.all; -- ieee.float_pkg.all; in the release entity round is port ( a, b : in std_logic_vector (31 downto 0); Sum : out integer; Clk, reset : in std_ulogic); end round; architecture RTL of round is signal afp, bfp, Sumfp : float32; -- same as "float (8 downto 23)" begin afp <= to_float (a, afp); -- SLV to float, using afp' range bfp <= to_float (b, bfp); -- SLV to float, using bfp' range process (clk, reset) begin if reset = '1' then Sumfp <= (others => '0'); elsif rising_edge (clk) then Sumfp <= afp + bfp; Sum <= to_integer (Sumfp,round_inf,true); end if; end process; end RTL;
