13 years agoFirst time CPLD use questions - internal pull up resistor and clocking with Max 7000S
I've designed a video game controller using Altera Max 7000s and Quartus 2 using the BDF process. 1-Was I suppose to add a clock? I only have inputs and outputs and logic gates needed in the ...
13 years agoI reviewed the datasheet for Max V and it discusses the weak pull resistor, the datasheet for Max 7000S does not mention pull up resistors. This confirms what I saw in Quartus II--> the Max 7000S does not have weak pull up resistor feature. I'll be installing an external pull up resistor on the inputs.
