13 years agoFirst time CPLD use questions - internal pull up resistor and clocking with Max 7000S
I've designed a video game controller using Altera Max 7000s and Quartus 2 using the BDF process. 1-Was I suppose to add a clock? I only have inputs and outputs and logic gates needed in the ...
13 years agoOk I found setting on Max V CPLD for Weak Pull-up Resistor" after I customize window in pin planner.
By weak I assume that means like 4.7Kohms or something, right? I find no such setting for Max 7000S (EPM7064SLC4410N) <--this is the CPLD I want to use as it supports 5v I/O operation. Does Max 7000S CPLD support internal pull up resistor, or does it need to use an external pull up resistor?
