16 years agoFilter & decimation implementation on AD7401
Hello everybody! We have chosen the AD7401 Sigma Delta modulator for our project, translated the Verilog code given by the datasheet into VHDL and are now confused about the results of the simu...
16 years agoThe original Verilog code is an example of bad coding style, involving word_clk designed as a ripple clock, but it's basically working.
You have confused the code by an adder, that hasn't been there before and apparently act's as a kind of random number generator in your simulation. if mdata1='1' then
ip_data1 <= ip_data1 + '1';
else
ip_data1 <= ip_data1 - '1'; The purpose of this combinational code is to assign 0/+1 respectively -1/+1 to ip_data1, not to sum up anything.
