15 years agoFile Compression in QUARTUS II 9.1SP2
I am currently using quartus ii software build 350 03/24/2010 sj web edition to design my Cyclone II based projects. I want to compress my .sof output files into smaller .jic ones to save time aft...
15 years agoHi scanner1306,
Which version do you have installed on your PC --- Quote Start --- I am currently using quartus ii software build 350 03/24/2010 sj web edition to design my Cyclone II based projects. --- Quote End --- You didn't tell us which version you are using. This is just the build number, the date of the build and it tells us that you use the Web Edition. Are you sure you have Quartus II 9.1 installed? Maybe you can install Quartus II 9.1 SP2 directly: https://www.altera.com/download/software/quartus-ii-we/9.1sp2 (https://www.altera.com/download/software/quartus-ii-we/9.1sp2)
