13 years agoFIFO to SGDMA, FIFO Stays FULL memory not written.
Hello all, still a little new to NIOS and avalon components, but I've been going at it for a few days and I'm a bit stumped. I setup an external counter being fed through a custom Avalon compon...
13 years ago --- Quote Start --- I think you forgot to start the modular SGDMA, so there is probably a descriptor stuck in the fifo waiting for the DMA to start. --- Quote End --- How do you explicitly start the SGDMA? The following
read_csr_control(MODULAR_SGDMA_DISPATCHER_CSR_BASE); returns 16 which from your manual should imply: Stop Descriptors is set. I try and call start_descriptors and start_dispatcher manually via start_descriptors(MODULAR_SGDMA_DISPATCHER_CSR_BASE); And if I check the control register status it's still at 16. So something isn't starting like you assumed, I'm just not sure how to get it going.
