15 years agoFIFO issues
Hello all, I've been working on a project involving the Altera FIFOs and things seem to be largely well. We've encountered one significant problem however and have had no luck debugging it. ...
15 years agoThe problem with using anything other than a real clock for a clock is that you wont always have a proper clock, and you are very likely to violate setup and hold times.
The best solution - use a real clock for BOTH clocks and use the buttons as the read/write enable
