10 years agoFast data tranfer to PC
Hallo, I am trying to implement a new project where I want to use an FPGA as a kind of DAQ system. Basically the FPGA is reading about 70 sensors sending asynchronously with a maximum bit rate ...
10 years ago --- Quote Start --- I don't follow your calculation. You need 48.3Mbits/s. The FT2232, I believe, will give you ~30Mbits/s (I don't know what 3Mbaud/s means, or where it came from). You don't seem to have enough bandwidth with the FT2232. --- Quote End --- You are right actually 3Mbaud/s means 300Kbytes/s and what I need is 6Mbytes/s (48.3/8). So it wont really work for all sensor.
