18 years agoFast Corner estimation for older devices
I am mantaining a couple of old designs with devices from the FLEX families. Being familiar with newer families only, I wasn't expecting all the Quartus limitations when targetting these old de...
18 years agoI made some tests with Apex families. Using the fastest speed grade I get approximately a relation of 2.5 between Slow and Fast model.
That was measuring tPD with a simple test design, combining a handful of inputs pins through a couple of LEs, to an output pin. Assuming the Flex families are not that different, it seems that I can safely consider a rule of thumb of dividing by 4.5 from the Slow Model results on the slowest speed grade. In others words, I should constrain minimum tPD to be 4.5 times the value I really need. Thanks again.
