18 years agoFast Corner estimation for older devices
I am mantaining a couple of old designs with devices from the FLEX families. Being familiar with newer families only, I wasn't expecting all the Quartus limitations when targetting these old de...
18 years agoMany thanks, Rysc.
--- Quote Start --- The addage I remember from around that time was, "compile for the fastest speed grade, then divide that number by 4". That's probably really pessimistic, but should cover all conditions. --- Quote End --- Dividing by 4 from the fastest speed grade sounds indeed a lot. This would mean that if I'm using the slowest speed grade, I would need to consider the best case being something in the order of, possibly 10 times shorter than the worst case ???
