15 years agoFailed to send UDP packets
Hello, We are trying to send video frames from one embedded system to another. As a preliminary step, we successfully sent the video frames from the transmitter to the PC using telnet ses...
15 years ago --- Quote Start --- Hello, Thank you very much for your reply. 1- I tried to make the server as you suggested in your link and after compiling and running the code on NIOS II IDE for eclipse the following messages are encountered: panic: unlock NET dtrap - needs breakpoint 2- Do you have a method to test such a server code. Your prompt response is highly appreciated. Thanks & Regards :) --- Quote End --- As a reference for anyone reaching this page from a google search... I had this unlock NET error and found that my problem was that I was trying to open a UDP socket before I had run the following: --- Quote Start --- alt_iniche_init(); netmain(); while (!iniche_net_ready) TK_SLEEP(1); --- Quote End --- I moved my UDP socket code below those lines and the error went away.
