15 years agoFailed to send UDP packets
Hello, We are trying to send video frames from one embedded system to another. As a preliminary step, we successfully sent the video frames from the transmitter to the PC using telnet ses...
15 years ago --- Quote Start --- I would strip out the asynchronous sockets and focus on getting UDP functional with simple messaging first. Do something like this (http://www.abc.se/~m6695/udp.html), first, and build from there. Cheers and good luck, slacker --- Quote End --- Hello, Thank you very much for your reply. 1- I tried to make the server as you suggested in your link and after compiling and running the code on NIOS II IDE for eclipse the following messages are encountered: panic: unlock NET dtrap - needs breakpoint 2- Do you have a method to test such a server code. Your prompt response is highly appreciated. Thanks & Regards :)
