15 years agoFailed to send UDP packets
Hello, We are trying to send video frames from one embedded system to another. As a preliminary step, we successfully sent the video frames from the transmitter to the PC using telnet ses...
15 years agoStop sending the same question multiple times... this isn't the first time you do it.
What IP stack are you using? I don't recognise those messages. There is probably an error in your source code, can you post it? At least the UDP part.
