13 years agoFailed to route the following 1 signal(s)-- global signals
The device is : cyclone V 5CEFA9F31I7 The quartus version is 13.0 the fitter often failed and report the following message: error (170143): final fitting attempt was unsuccessful ...
13 years ago --- Quote Start --- By the looks of the number of clocks you have are stressing the global routing resources of the design. The Device has 16 GCLK, My design have only used about 9 GCLK. I don't know why I stressed the global routing resources. Can I manually constrain the Global signal distribution to guide the fitter? Does it work?
