binupr
2 years agoF-tile "Tile Interface planner" not showing legal locations for PCIe Streaming IP
Hi, I have two F-tile PCIe Streaming IPs in my design. I opened "Tile Interface Planner" to place these IPs to corresponding banks. But for some reason when I double click to see the legal locations...
RongY_altera
Contributor
2 years agoHi,
In a PCIe example design, you need to assign pin locations to hip rx/tx pins, e.g. hip_serial_tx_n_out0.
A easy way to assign all PCIe including related pins. You could select the top module, e.g. pcie_ed, then choose one of the legal locations shown as attached pcie_interface_planner_all_pins.png. This will complete all pins as shown in pcie_interface_planner_all_pins2.png.
Rong
- binupr2 years ago
Hi Rong,
What I mentioned was a custom design and not Intel reference design. I already found the issue. Firstly the issue was that the tile planner didn’t show any legal locations. In my design I didn’t want all to assign all lanes in a PCIE IP. But Quartus doesn’t like it. Hence not showing legal allocations. There must be a way not to use all lanes in an IP. Let me know if you have idea on that.
Btw, I have previously generated intel reference design for PCIe. You don’t have to assign hip tx or rx pins. The generated project already has the pins allocated.
BPR- RongY_altera2 years ago
Contributor
You mean to assign only partial pins of a 1x16 then use it like that?
The PCIe can be downgraded when host has less lanes. Or you can set PCIe IP to 1x8 to use less lanes.
Rong
