18 years agoexternal clamping diode for Cyclone 3
During implementation I get the following fitter warning: Warning: Following 1 pins must use external clamping diodes. Info: Pin Nios2Processor:\b_uP_MemInt_I2C:i_Nios2Processor|epcs_controller:the_epcs_controller|tornado_epcs_controller_atom:the_tornado_epcs_controller_atom|the_tornado_spiblock~ALTERA_DATA0 uses I/O standard 2.5 V at N7 My design uses an EPCS flash (powered @ 3V3) and it uses pin N7, which is situated in a 3.3V bank. This is confusing: - The handbook uses a clamping diode to Vccio, in my case that is 3.3V - Quartus tells me to add a clamping diode, it doesn't specify to which voltage but I guess that it is the 2V5 - Is the input buffer for the data0 pin powered by Vccio (3V3) or by Vcca (2V5) ? Can you clarify this? thanks and best regards, Karel D1 Reply
When you use a configuration circuit suggested in the handbook, you should simply ignore the said warnings.
