13 years agoextend PCIe interrupt with Qsys
Hello, I want to implement a project on Cyclone IV GX FPGA which produce customs interrupts which are sent to the kernel through PCIe using MSI. From the side of the linux driver pci_enable_...
13 years agoI have asserted RxmIrq and app_msi_req signals (Signals that are responsible for Interrupts as it's said in the IP compiler user Guide) every 100 cylces.
In simulation, I saw that it is asserted app_int_ack every time that RxmIrq and app_msi_req are asserted. BUT NOT app_msi_ack is turn to 1. I guess that this is happend because of the configuration of the testbence ( INTx is enabled instead of MSI). Nevertheless I can not see interrupts from the side of the software. Any advices ? Do I miss something important? How can I set the simulation from INT to msi mode? Thanks you.
