13 years agoextend PCIe interrupt with Qsys
Hello, I want to implement a project on Cyclone IV GX FPGA which produce customs interrupts which are sent to the kernel through PCIe using MSI. From the side of the linux driver pci_enable_...
13 years agoI have read the PCIe user guide and I found that the signal app_msi_req produces the interrupts to pci express.
Also I check the followed registers that are responsible for generating msi interrupts: 1. Set the MSI Enable at bit[0] of MSI Control Status register, this bit is mapped to bit[16] of configuration space register offset 0x50. 2. Set the Interrupt Disable at bit[10] of Command Register at configuration space offset register 0x4 to disable legacy interrupt. 3. Set the Bus Master at bit[2] of Command Register at configuration space offset register 0x4 to enable the ability to generate MSI message. Every 1 sec I enable the app_msi_req inorder to see every 1 sec interrupts in my driver. app _msi_tc and app_msi_num assigned to zero. Still I can not see interrupts in my driver. The interrupt handler is not called. I would like to ask: 1) What should I check more? Do I miss something important? 2) How can I simulate this desing to check if I get app_msi_ack=1 ?? 3) Should I change more signals? Thanks in Advance!
