8 years agoExport synthesized top-module and import in another project
I am working on a project where different engineers will be developing different modules of a large design completely separately. The design must be entirely bottom-up because the module developers m...
8 years agoSorry about the duplicate post.... I did not see my reply in the thread.
I am going through that training class that @strell mentioned. My confusion remains. I want to export my entire project/design as a synthesized netlist (ONLY synthesis)... not a sub-module of my design. How can I do this, if I cannot export the top level of my design as a partition? Do I just use the '--export_design' option to quartus_cdb? I cannot figure out how to do this in the GUI, but like I mentioned before I ultimately need to do this all via command-line or Tcl. The Altera docs and training always export a sub-module as a partition. I want to export my top-level module as a netlist and import it elsewhere as a submodule. And to reiterate, I will only be running synthesis on this module. Fitting and timing will not be run until all submodules have been included in a final design. Thank you, David
