10 years agoExponential function in vhdl
hiii I want to implement exp(x.^2) in VHDL for synthesis. Can any one suggest how to do it. Here x is in signed format and i want result in fixed point arithmatic i.e. without rondoff operation....
10 years ago --- Quote Start --- If not function then should I write any package for exp. Sorry I havent written any lookup table before so I dont know. And actually I want to design a Gaussian filter with variable window size & sigma value. For that I am using two 1D gaussian. So the part I want to impliment is Gauss= exp^(-(x^2)/2*(sigma)^2); here sigma will vary from 0.1 to 5. and x is a vector =[-2 -1 0 1 2] for length equal to 5. I want to vary length also. How to do it.please help me with this. If you know any book for these type of operation then please suggest. --- Quote End --- Any equation can be implemented in fpga as LUT either fully or partially. In the partial case you do in fpga what is doable and then use LUT. In your case I suggest: get x^2 in fpga (x * x), one multiplier get 2* sigma^2 in fpga, one multiplier and add one zero lsb truncate above results to suitable bitwidth divide -x2/(2*sigma^2) in fpga if you can afford a divider, else include this section within LUT finally get LUT for your exp in software e.g. matlab and put it in a rom To get LUT of exp: you need to know range of your result. then just calculate exp of that range in suitable steps and rounded to your rom bitwidth Then in fpga address LUT with actual fpga result.
