18 years agoethernet connection
I've been checking web server and simple sockect server applications. Both applications need to connect the host and the FPGA board to a network. How Could I do a local connection between the h...
18 years agoYou are correct and incorrect in your thinking. Yes the two need to be connected to a network. Specifically they need to be connected to a network that supports IP addressing. However, that network can consist of a single cable between your PC and the board.
1 - Grab an extra network card and plug it into your PC. 2 - Use the OS to configure your new network interface to use Static IP addressing and give it an IP address and set the subnet accordingly. 3 - Set the Simple Socket Server example code to use static IP instead of DHCP and set the IP address and subnet accordingly. 4 - Connect your new network interface on your PC to the network interface on the FPGA board. You may need a crossover cable or adapter. Many PHYs now have crossover built in. If your network doesn't show a connection then you need a crossover. Jake
