17 years agoErrors reading M9K dual port in Cyclone III
Hi, We are using four Megawizard generated dual ports in a 3C40F484C8. There are 128 locations, 24 bits wide, asynchronous write and read clocks. A common write_data and write_address bus goes to ...
17 years agoHi, I have not worked much with running scripts. Can someone give a quick explanation of how to run the script described in the solution id /rd04302009_15 that was mentioned above?
