17 years agoErrors reading M9K dual port in Cyclone III
Hi, We are using four Megawizard generated dual ports in a 3C40F484C8. There are 128 locations, 24 bits wide, asynchronous write and read clocks. A common write_data and write_address bus goes to ...
17 years agoCan you post the exact MW options you used to instantiate the M9K block in your design? If possible please attach the HDL code of the instantiation.
