17 years agoErrors reading M9K dual port in Cyclone III
Hi, We are using four Megawizard generated dual ports in a 3C40F484C8. There are 128 locations, 24 bits wide, asynchronous write and read clocks. A common write_data and write_address bus goes to ...
17 years ago --- Quote Start --- adding SignalTap to the read side quite often stops the error from occurring --- Quote End --- is indicating timing problems, usually.
