17 years agoErrors reading M9K dual port in Cyclone III
Hi, We are using four Megawizard generated dual ports in a 3C40F484C8. There are 128 locations, 24 bits wide, asynchronous write and read clocks. A common write_data and write_address bus goes to ...
17 years agoCan you SignalTap it and capture addresses and data in and out? How do you know it's the memory and not something elsewhere.
If it occurs when cold, it might be a hold violation. Where do your read and write clocks come from? Are you sure the data in and control is clocked on the write domain while the read data is clocked back into the read domain? (If you're not analyzing between the domains because they're asynchronous, then clocking something in the wrong domain wouldn't show up static timing analysis)
